[FS: GEAR] Arri Alexa Classic + Convergent Design Odyssey 7Q+ RAW recorder
Cedric Letsch
San Francisco Bay Area
www.cedricletsch.com
$8000 shipped to lower 48
I haven’t used my Arri Alexa Classic + Convergent Design Odyssey 7Q+ RAW recorder lately so I’m considering selling the kit. 5182 hours – high speed license – serviced by Arri Munich in January 2021 (camera checked, recalibrated, QC image quality and function test carried out; viewfinder checked completely, rubber eyecup replaced, and function test conducted). Everything is in excellent working condition. Yes, I have the receipts. No, I'm not willing to split up the set. If it's up it's still available.
The fantastic thing about ARRIRAW is that - in combination with the ARRIRAW converter - it enables the same 4K image quality as the current Arri S35 cameras (Alexa Mini, Amira, Alexa SXT W), since they all use the same ALEV III sensor.
Pictures: https://www.dropbox.com/sh/mkvm2u8hp...okqkBmJma?dl=0
• Arri Alexa EV #2923 w/ high speed license
• Arri EVF-1 #2237 w/ blue microfiber eye cushion
• Leitax EF Mount (original PL mount included)
• Anton Bauer Gold Mount plate
• IDX A-AB2E V-Mount adapter
• Arri viewfinder mounting bracket VMB-1
• Arri viewfinder extension bracket VEB-1
• Arri viewfinder cables short (KC 150-S) & medium (KC 151-S)
• Arri center camera handle CCH-1
• Arri handle extension block HEB-2 (with tape hock)
• Arri wedge adapter WA-1
• Arri bridge plate adapter BPA-2
• Arri leveling block LB-1
• Arri shoulder pad SP-3
• 2x Sony 128GB SxS PRO+ cards
• Sonnet Echo ExpressCard Pro card reader (including Thunderbolt cable and USB-C adapter)
• MiniMic & cable to 5-pin female XLR (https://location-sound-london.myshop...Uz5fvgvSZv3B1k D_qeR1EcTeEGRMhdhLDg8bafao)
• Sommer 10ft 5-pin male XLR to dual 3-pin female XLRs. Stereo Y Lead. Balanced Cable.
• SmallRig VTC-14 plate
• Arri case
• Odyssey 7Q+ w/ RAW & APOLLO licenses
• 2x Samsung 1TB SSDs
• 2x SDI cables
• Mini HDMI to HDMI Cable
• SmallRig magic arm
• AC power supply
• D-Tap power supply
• Brand new screen protector
• Odyssey Nanuk 910 case
• 2x Juicebox 150Wh Gold Mount batteries & charger
I can also add any of the following:
• Sachtler Video 14 II fluid head (100mm bowl, takes up to 33lbs)
• Sound Devices MM-1 (fantastic mic pre-amp with phantom power, outputs line signal to camera)
• Nikon AF-S 17-55/2.8 DX with Nikon F -> Canon EF adapter (aperture can be adjusted mechanically)
• Fotodiox Nikon F to Canon EF adapter
Hi Cedric,
Might be interested in the Odyssey if you want to split that off.
j
