Sanjin Jukic
- Dec 28, 2006
- Vienna, Austria
- www.sanjinjukic.com
Please - don't let the fanboy get the better of you. While the KI Pro is a very cool product, it does not record in ProRes 4444, but rather ProRes 422. Also - nobody knows the quality of the signal the Alexa outputs vs. the 720p signal the RED outputs. Also - having two different boxes to manage with signal & power-cables isn't exactly as elegant as the Alexa where everything is built into one single (and - IMHO - well-designed) box. The HD-SDI signal coming from the RED is fine for monitoring but isn't exactly broadcast quality (as far as I understand in terms of debayer quality).
Tony,
OK, you have 422 the best out of KiPro but isn't all broadcast at 8bit 422 quality anyway.
For ProRes 444 you have REDRocket to convert if you need it.
Also don't make fun out of RED's HD-SDI quality and try out once yourself to see how it is good.
If you talk about cables with extra boxes then just have a look below and imagine how many cables you would need to record higher than ProRes on Alexa:
Taken from Alexa workflow pdf.
That's all my dear fellow RED funboy!
