Yes, I have OSXFuse installed and I can get the GUI running. The tape isn't mounting because of some kind of error. Which is why I need to be able to run the Terminal command.
I think this is what happened but the odd thing is that it just threw the error while in the middle of writing, no force eject or power cut. And then after that it refused to mount. Sounds like a full recovery could be a winner.
Hi Tim,
Thanks so much for taking the time to respond to this. To be honest the HP guys don't seem to know too much although they are trying to help. I now have new tape drive and exactly the same issue. It's connected with an ATTO card. Really bizarre...
I tried the command with a blank tape and it throws back this message:
dyld: Symbol not found: _UCNV_TO_U_CALLBACK_STOP_4_0
Referenced from: /Library/Frameworks/LTFS.framework/Versions/Current/usr/lib/libltfs.2.0.0.dylib
Expected in: /Library/Frameworks/ICU.framework/Versions/Current/usr/lib/libicu.40.1.dylib
in /Library/Frameworks/LTFS.framework/Versions/Current/usr/lib/libltfs.2.0.0.dylib
Trace/BPT trap
Is there something missing from my Library?
Also, I forgot to mention that it also means that your existing tapes are probably okay and will be recoverable using ltfsck after you get the drivers restabilized.That is indicative of a bad LTFS driver installation. The specific error indicates that the ICU package hasn't been properly installed (why it's needed, no one can tell me other than it was part of IBM's original source files). Check your DMG that you installed LTFS from and make sure that you install the ICU package.
