Robert Hart
- Feb 26, 2012
With the SI2K, the Anton Bauer Titan mains power pack/battery charger works fine with the SI2K. The product is a power pack which fits on a standard battery gold mount. An Anton Bauer gold mount battery then sits on it. When no mains power is applied to the charger, the battery power is routed through it to the camera-recorder. When mains power is connected, it supplies battery-level power to the camera-recorder. When the camera-recorder is turned off, the power pack then re-charges the battery. If there is a battery fitted and the camera-recorder is running off mains power and some clown hangs a toe in the power cable or plugs in a heavy light and trips a breaker, the power pack seamlessly switches in the battery. --- My question is, does the RED camera family play nice with the Anton Bauer batteries and the Titan power pack or do things go wrong? I ask because there may come a need to supply seamless power to an under-resourced Scarlet camera next year. As I already own and use the Anton Bauer kit for the SI2K, it would be a pity not to be able to use it on the RED cam instead of getting hold of stuff from elsewhere. Any advice would be appreciated ESPECIALLY if there is a risk of something getting a bit crisp and smelly inside the RED cam which I do not want to ruin for the owner.
