[FS: OPTICS] ANGENIEUX Optimo 45-120 cinema lens 28 - 76 cinema lens 15 - 40 cinema lens / 3 LENS
tim ara
REDuser Sponsor
LOS ANGELES, CALIFORNIA - USA
www.cinoflex.com
ALL IN PERFECT CONDITION
INCLUDES
3 CASES
3 PANAVISON MOUNTS
3 SERVO MOTOR BRACKETS DUCLOS
3 HEDEN ZOOM MOTORS
PERFECT OPTICS
MAINTAINED BY PROFESSIONALS THROUGHOUT LAST 2 YEARS OF LIFE
located in Los Angeles, CA $172,500.00 for the set
45-120MM OPTIMO
Aperture:
f/2.6 - T2.8
Zoom ration: 2.7X
Weight (approx.): 4.3 lbs - 1.95kg
Length: 203 mm
MOD: 3 ft 1 in - 0.94 m
Image coverage: S35 + 31.4mm diagonal
. Exceptional optical quality enables the 45-120 to rival the best prime lens series at equivalent focal distances.
. Perfect homogeneity of colorimetry, contrast and resolution.
. Compact and very light (< 2 Kg), centre of gravity identical on all compact zooms.
. For high-end film and digital cameras.
. No breathing, no ramping.
. Focus scale with over 50 witness marks for precise focus position. Easy interchangeable scale between imperial and metric
. Minimium image circle 31.4mm diagonal, perfect for Super 35 film and digital cameras
. Available in PL mount. Panavision, Canon EF and Nikon F mounts available on request
. Compatible with Optimo 1.4x and 2x extenders, and DSLR mounts.
. The precise witness marks and mecanics of the lens and its superior optical quality enable you to shoot cutting edge productions.
. In Super 3T mm format while maintaining your highest expetations of quality.
28-76MM OPTIMO
Aperture: f/2.4 - T2.6
Zoom ratio: 2.7X
Weight(approx.): 4.2 lbs - 1.92kg
Length: 186 mm
MOD: 2 ft - 0.6 m
. Exceptional optical quality enables the 28-76 to rival the best prime lens series at equivalent focal distances.
. Focus scale with over 50 witness marks for precise focus position. Available in feet or meters
15-40MM OPTIMO
Zoom ratio: 2.7X
Weight (approx.): 4.2 lbs - 1.92kg
Length: 186 mm
MOD: 2 ft - 0.6m
Image Coverage: S35 + 31.4mm diagonal
. Exceptional optical quality enables the 15-40 to rival the best prime lens series at equivalent focal distances.
. No ramping, no breathing.
. Compatible with Optimo 1.4x and 2x extenders, DSLR Mounts, Wide Angle 0.75x.
Are you willing to split the 45-120mm lens and sell ? If so... how much please?
