Anamorphic lenses wider than 24mm?
Nathan Wold
Active member
Are there any Anamorphic lenses made that are wider than 24mm? Widest I can find is Cooke's 24mm.
Considering that's basically a horizontal 12mm field of view I think it'll be hard to find something wider
Well, there were NPO EKRAN (CKBK) ones. Do not ask me how or whether it's possible to find these unicorns:-)
BAS26-1 22mm f2.8 Datasheet taken from NIKFI lens review of 1978:
7h96HH
BAS39-22-1 22mm f2.0 reduced Datasheet with main optical data, from NIKFI review of 1989:
w1j774
Wow, thanks! I totally want that lens even though I know I will never find it!
That's tough, you don't really hear about ultra wide and anamorphics in the same sentence. I've tried to use adapters with really tiny SLR lenses like my Spiratone 20mm 2.8 but none of them cover that wide and the widest I've gotten is 28mm on full frame with the Panasonic anamorphic adapter. I was inspired by Michael Bay because I read that he had a custom 20mm anamorphic lens made for, I think, either "Pearl Harbor" or one of the first two "Transformers" movies. Whether that lens is available for rent somewhere out there, I don't know, but that's that widest anamorphic I've heard of. Another option for wide anamorphic use is the Cinemorph mod for the Canon EF version of the Sigma 18-35 zoom lens from Vid-Atlantic, it's not a true anamorphic but it gets you similar flares and bokeh that should cut together nicely.
Ian, that Arri zoom has back anamorphic attachment so the look would be spherical. Still, I bet at 19mm 2x squeezed it is something if its own.
Ilya, correct. Yeah, it is a very crazy look to play with.
