RED BOMB EVF [LCOS], hard case
In great condition, comes with hard case.
$900
Action Products Apollo Epic Top Plate
Perfect for Steadicam builds--breaks out Sync and distributes 12/24v power.
The plate bolts directly to the top of an MX body, for a Dragon body all you need to do is dremel/mill out the grill on the plate.
$375
REDMAG 1.8” Firewire 800 / eSATA reader, Power Supply
In good condition and works perfectly. There is a ‘P’ etched on the underside—see photos. Comes with AC power lead and eSATA cable.
$100
Element Technica RED PRO EVF Mount
The most solid EVF solution I’ve found for Epic/Scarlet (though you can use it on almost any camera setup with a top plate). You can adjust and/or lock the drag with the wheel on the EVF Clutch Assembly, almost like on an Arri setup. Comes with RED PRO EVF interface.
https://elementtechnica.com/product/10012012/
$600
Wooden Camera Leather Side Handle
Great condition.
$100
Wooden Camera A-Lock for RED
Super handy for mounting quick back plates onto cheese plate, side ribs, or anything else.
$60
Cheese Plate w/ 19mm clamps
1/4”-20 and 3/8”-16 holes, 1/4” slots. Cheese plate measures about 70mm x 140mm.
Will throw in additional cheese plate for free.
$60
Sachtler Touch and Go 16 Quick Release Camera Plate 1064 (DV12, Video 15/18/20/25, 18 Dutch)
For fluid heads DV 12, Video 15 to 25 and Video 18 Dutch. Used, missing one rubber piece. Comes with 3/8” captive screw. Measures about 65mmx78mm.
$55
Wooden Camera Shoulder Rig
Standard Arri dovetail with safety; very comfortable to operate. This version uses the foam pad which is softer and interchangeable. Rosettes are sharp (also Arri standard, compatible with all Arri parts on both sides).
$700
19mm to 15mm adapter
Quick solution to mount 15mm accessories on a 19mm setup.
$30
Pair 18” 19mm rods
Aluminum; straight.
$40
Pair 18" 15mm Stainless Steel Iris Support Rods
One pair, stainless, straight.
$40
Pelican 1650 case
In great shape. Comes with foam as pictured; I have a bunch of additional pick-n-pluck foam if you need it.
NYC pickup only.
$175
All located in NYC. Ship, or pick up.
Shoot me a message for photos of items you're interested in.
$900
$375
$100
$600
Great condition.
$100
$60
$60
$55
$700
$30
Pair 18” 19mm rods
Aluminum; straight.
$40
$40
Pelican 1650 case
NYC pickup only.
$175
