Well, if you are looking for supporting a red with the 3063, I wouldn't. It doesn't have a counter balance, and even if it did it would be no where strong enough. When I first started out I bought a 3063. It's not a bad head, except that it's not really a fluid head. It uses friction and grease to add "smoothness". The only problem is that it's really hard to get a smooth tilt/pan with it. It does okay with a light camera and if you use a couple of rubber bands tied together to remove any jerkiness that your hand might add. Personally, I would save your money and at least get a Libec or spend a few hundred dollars more and get a used low end Sachtler.
The heaviest it will ever see is a HVX200 or maybe a scarlet one day and its
my intention to permanently mount it on a DIY slider.
I've heard that older fluid heads can leak and I just don't know what to look for.
Whether problems like leaks are hard to detect with an inexperienced eye,
or whether you can tell right away.
It's $400, but if you can't make your money back on it you need to find a different business Plus, after using sliders in the past (much higher end ones), it is really vital that you have a good fluid head on one. They are not easy to use and a good head makes a world of difference. Trust me, after owning a 6063 you will be much happier that you spent a little more right now than having to upgrade in a short time when you realize that the 6063 isn't that smooth.
