adobe premiere problem please help!
emrete
New member
Hi,
I've just finished a project with red one and want to edit it in Premiere CS5. But there is a strange problem. I can import r3d files successfully but I can't see nothing. Only sound. I think it is a codec issue. Am I going to install some additional codecs to my computer for working in premiere with r3d files? If yes where can I find them? Please help me. Thank you.
Hi,
Need more info here. You shouldn't need to install anything. Make sure you select the .r3d not any of the .mov's
Cheers
Dave
What camera firmware version is your footage shot with? Are you on a Mac or PC? Is it a serialized version of Premiere Pro or a trial version? Are you using any additional video hadware or plugins (i.e. Blackmagic, Matrox, or AJA)? You should not require additional codecs as Premiere Pro CS5 handles Red footage natively.
Open in RedCine-X. If same problem, then check your RGB setting (should be 1, not 0).
