Peter Karlsson
- Jan 21, 2007
- Age
- 52
- Stockholm
- www.flowcine.com
I´ve tried to search for this topic, but couldn´t find anything.
My question is regarding the compression artifact you get with "redcode". I will mainly use the Red One in a greenscreen studio. Now I´ve only looked at material shot by Jon Firestone, Chris Bagley over at Redrelay.net. I´ve heard by others that the Red is the BEST for keying, but Im somewhat pussled over my own results. I can see heavily artifacts when pulling a chromakey on the material by Jon Firestone and Chris Bagley. It soo nice to see material with as little noise as this, but its heartbreaking to see the material ruined by the compression.
I know that the codec isnt finished, and I don´t know which build this was shot with. But my question is basically if there are any plans on letting the user be able to shot with a lesser compression but with a higher data rate as result? Is the red drive able to keep up with higher data rates that the CF cards? Or is the raw port the only way to go if you want to be able to pull the cleanest key out there?
/regards Peter K
/regards Peter K
