Zach Tucker
- Dec 30, 2008
- Age
- 51
this may sound like a repeat post but it actually differs from the other sensor size DoF threads.
Anyone know what the *usable* size of the 2/3" scarlet sensor will be? yes, there will be speculation but maybe it will be relative to the usable size of the current red one sensor ( some percentage? ). meaning, if the 2/3" sensor is 10.1mm x 5.35mm (and thus a diagonal of 11.4mm by my calculations) then is 100% of that sensor used to capture an image? (let's ignore aspect ratios for now and just stick with full horizontal specs)
the reason i ask is that clearly this old glass tube thirds-of-an-inch sensor size hoo-ha is a total generalization. 2/3" on one camera is not the same as 2/3" on another. and even if the chip sizes were the same on two different 2/3" cameras their actual usable area may differ.
ultimately i'm trying to find DoF specs on the 2/3" scarlet. let's take a given FOV achieved with a 75mm lens on an S35 scarlet at say, f4.0. to get a similar FOV on a 2/3" scarlet (given current list of mini-red primes) i'd likely use a 25mm T1.8. so, cool, i've matched FOV, now what happens with my DoF? if i shoot the 2/3" scarlet with 25mm lens set to f2.0, what would my DoF be like now that i'm open 2 more stops than on the S35 75mm at f4?
in using various DoF calculators i'm finding a wicked discrepancy. almost all the calculators have presets. "full frame 35mm" "canon 5d" "2/3 sensor", etc. well, on two different calculators (when using the 2/3" sensor preset for film back) they can differ as much as 200% ... soooo that's whack. i guess it's understandable given the inaccurate legacy thirds-of-an-inch sensor specs.
so, in the end:
1) guesses on usable horizontal size of the 2/3" 10.1mm sensor?
2) anyone know of a DoF calculator that i can put my own sensor specs into?
.z
so, in the end:
.z
