Caleb Norman
Action Products Calypso, Proteus, Apollo, Electra, & SDI Splitter – RED Dragon, Epic, or Scarlet DSMC1 - $700
APOLLO top plate w/ screws
- Relocates HD-SDI port up top for ease of reach.
- Break-out from SYNC port to 3x SDI's: Timecode, GPI and Genlock (similar to WC's B-box but more elegant).
- Provides 2x 12volt Lemo-2pin ports (Arri-standard), one on each side, 1x 12volt Lemo-4pin port (Red-standard) and 1x 12/24volt* Fischer-3pin port (Arri-standard).
* 24volts only when used in conjunction with ELECTRA module (below).
PROTEUS module w/ screws
- This acts as the brain for all the other modules, routing power from the ELECTRA module (below)* to the DSMC (via the Lemo-6pin pigtail) and to the APOLLO top plate (above).
- Relocates the headphone port for ease of reach.
- Provides a 5volt Fischer-2pin port
HYDRA HD-SDI splitting module w/ BNC jumper
- Splits input in to 4 outputs, 3 on side and 1 underneath.
- Accepts 3G, HD and SD signals, works with all DSMC outputs.
- Power toggle switch with power/signal indicator LED's.
- Requires PROTEUS module (above).
ELECTRA power module V-Mount
- Includes buffer circuitry and internal battery so you can hotswap bricks without powering down DSMC - by far the best feature of the AP modules.
- Relocates the DSMC's Lemo-6pin power-in port for running off AC adaptor. Also includes XLR4 input port when using block battery.
- Provides 1x 12volt Lemo-2pin ports (Arri-standard), 1x 12volt Lemo-4pin port (Red-standard) and 1x 24volt Fischer-3pin port (Arri-standard).
- Provides 2x 12volt Ptap ports, one on module and one on battery plate.
Action Products Epic/Scarlet/Dragon XLR Audio adapter
- Acts as a bottom riser plate
- Converts the (2) ¼” Mic inputs into 2 channels of XLR inputs.
PayPal or Local Pickup.
PM or email me at caleb1189@gmail.com for any info
Located in San Diego, CA
