A solution for Hand-held and tripod
ALLSTAR
REDuser Sponsor
47
www.allstarcine.com
Allstar Dual bridge plate is a very good solution for Hand-held and tripod. This is an Arri type bridge plate which has a upper dovetail. It is made of 7075 aluminum and did hard anodizing for surface treatment to provide strong and wearproof surface.
Because of the double dovetails design on Allstar Dual bridge plate, you won`t need to mount shoulder pad with the whole bridge plate, just use a 8mm high plate. So the optical axis of lense will be under your eyes, and get lowest center of gravity then Arri style shoulder rigs.
REDONE is a little heavy and the center of gravity is on the top, so getting lower center of gravity is most important when doing Hand-held.
Allstar Dual bridge plate introduction video:
