Daniel Christensen
I've been digging incessantly regarding RED workflow recently, and haven't had much luck. You know how the internet is, can't find anything current or relevant.
Before I start, I should probably give some background as to where I'm coming from. I've only shot on DSLR's. So basically I shoot, dump all the SD cards onto my computer hard drive, then import them into Serif MoviePlus (on my older PC) or iMovie (on my mid-2013 Macbook Air) and start editing away. I've taken to doing some minor color adjustment in iMovie, just to keep my films from looking too much like home movie crap. Once I'm finished with the movie, I transfer all the footage, audio, project files, etc. to an external backup hard drive and forget about it.
Correct me if I'm wrong, but I won't be able to use that same workflow (i.e. taking the REDmags, sticking them on a hard drive, editing, coloring, exporting as a .mov) with a Scarlet. And here's where they brainless noob questions start.
First, is it at all possible, on, say a full-spec iMac or some iteration of the new Mac Pro be able to edit RED files with the workflow I talked about above? Second, what does the RED Rocket/-X actually do? Can someone give me a simple explanation of what it does? Does it only work within REDCine-X Pro? Or would it work within Premiere Pro CC, or Final Cut Pro X, or Smoke 2013? What does it do within those programs? For a working professional would it be worth it to have the Red Rocket? If I had the Red Rocket, would I need to use a proxy workflow? Or could I stick with a similar workflow to what I outlined above?
I know this is kind of a loaded question, and no one person will be able to answer all of the "sub-questions" but I'm really striving to understand this whole RED workflow process, and any help would be appreciated! Thank you!
