Ivan Cortazar
It won't come with any other product. You may have to make one by starting with this http://www.bhphotovideo.com/c/product/69226-REG/Anton_Bauer_PTOE_PowerTap_Open_End_Cable.html and adding the connector that fits the monitor. Just make sure to keep the polarity straight or you might toast the monitor.
Thanks again Larry. I have an electrical engineer friend that I will ask before I connect the parts... as I have no idea what polarity means... :biggrin:
Any difference between the Carrion A and the C series aside from the 2 HD-SDI outputs?
It seems that they are both identical and the price is 425$ cheaper. Is it worth it going with the HD-SDI since the REd camera has those outputs anyway? Would it be possible to connect the A version via HDMI to DVI as an onboard monitor and if you want to connect an extra monitor use the camera HD-SDI ports. But probably the Red won't output HDMI and HD-SDI at the same time, right?
One downside for me with the Carrion instead of the LCD-PRO is that I was thinking to get one Dell or a cheap Hans LDC monitor and use it as an extra monitor via HDMI, but if I connect the Carrion, then I won't have any HDMI out left.
I guess you can't have everything in life....
