7" not turning on in top pogo
Mike Simpson
NYC/LA
www.mike-simpson.com
Hey there. Curious if anyone's run into this issue. I've installed the latest firmware. My 7" dsmc2 works fine for a bit , then the touch will stop working (usually after a few hours), then if I unplug and replug the monitor in it will not turn on at all.
Works fine in the side pogo slot. Even after it stops working on top.
I've had to reinstall the firmware twice to restore top functionality.
I'm just gonna try an old firmware now but curious if anyone's had this issue or has other suggestions.
Just as an update I still have the same issue. Tried reinstalling the firmware 3 times. Weirdly it goes the same, everything is fine for a while, then i lose touchscreen funcitonality, then if i unplug the monitor or reboot the camera the monitor will not turn on.
After a while everything will just go back to working (so far either after lunch or the next day).
And again absolutely no problems on the side pogo.
No one else has run into this?
