I suppose you can use the Kona for this purpose, but is this a final mix or just playing around? Surround is not as easy as it may seem. There is a lot to know, especially in terms of acoustics, because if you are not set up to do it properly, you can run into problems with speakers not aligned properly, stereo mixdown issues, etc.
Theoretically though as long as the Kona is seen as an audio device, the apps should be able to route to it and yes, you should be able to use it. But keep in mind that it has AES outputs.
