[SOLD] 4x Granite Mini Batteries -- Gold Mount (2x 95wh and 2x 140wh)
Ben Sturgulewski
Girdwood, AK
www.sturgefilm.com
These are moderately used batteries and have the usual cosmetic issues for used batteries, light scratching and scuffing. PM for pics. They all have relatively low hours and have a ton of life left in them. They are smart WiFi batteries so can use the BlueShape app to track battery health, cycles, etc.
One thing of note-- the gold mount studs seem to have had issues fitting onto certain plates. If the connection is loose, you may need to add small washers behind the gold studs to firm up the connection. This is a known issue by Blueshape and they sent me the washers to add, and that fixed the issue on my plate-- but it may have made the connection too tight or loose with other plates. More than likely it will be fine on your plate, but if not it is an easy fix by either adding or removing washers. I am not including washers.
These retail for $1800 or so, looking for $675. A lot of wH for the price!
