- Banned
- #1
Tony Hernandez
Banned
- Mar 11, 2011
4K120P SSD USB SDXC Recorder & 5.7 inch monitor & portable PC for DSMC1 DSMC2 cameras
Hello guys, I hope you like this, with permission of the administrators and the great people at RED, what is this is currently a prototype, but will be available after summer, before end 2016..
That's what we have developed, to use with our Raven just we got, but will be compatible with DSMC1 as well as DSMC2 cameras. It is basically a Windows 10 device at the palm of your hand,
running Red Tether to provide recording over GIG-E port up to 4K120P as well as 5K and 6K at a lower framerate.
Info about -according to RED data- the maximum framerate and quality:
So 4K120p at 12:1, and 4K60p at 6:1, 4K50p at5:1, just double the above numbers as RED wrote an example using 500 mbps port and this device have a 1Gbps port.
I will need to wait for Jetpack SDI or redvolt expander (xlr module) to be able to make the recording tests, so please wait. If anyof you guys have a DSMC1 and can come to Barcelona, please send me an email, as DSMC1 camera by default have the GIG-E port, Raven currently need jetpack SDI or redvolt expander.
If all goes well, with this device, you'll be able to record onto any media, so you can compliment the red ssd's or not, so you can record on to cheap media, and also you'll be able to monitor what your camera provides, at a great resolution, as this device have a QHD native resolution display, so a 5.7 inch display with 2560x1440, this device will also allow you to edit in-situ, send share, etc ..
It can use usb drives, the internal SSD M.2 drive, or even SD cards (sandisk at 95MBps or superior, UHS class 1).
I hope you like it, It might be of your interest ?
