Sergey Afanasiev
Hi. Once I heard an advice for 4K editing in premier pro cs6. One guy told me that it is better to create a 1920x1080 sequence. Then if you put a 4K clip on the timeline you'll need to scale the clip to the frame size (1920). The reason: it will be faster for output encoding. I have only one question: will I lose the quality if I scale the footage? I think the quality much better when make a 4K sequence and then make the rescaling to 1920 only when exporting the final result... Or I am wrong?
