2/3" mini-red mount question
David Rasberry
Is the mini-red mount large enough to allow conversion of c-mount 16mm zoom lenses to MR bayonet with a screw on adapter similar to Bolex?
The benefit would be not having to constantly change mounts if you wanted to use the mini primes with c mount zooms. At least that's where I think David is coming from?
Scarlet will have a C mount available so I'm not sure what the benefit of converting the lens would be?
Mainly convenience if it were used in conjunction with a set of MP's. No need to change mounts and you get the advantages of a locking bayonet mount.
