Norbert Jalitsch
- Oct 1, 2008
- Age
- 51
- Vienna
- www.dsmworx.at
i have a few questions, hopefully someone can bring any light in the dark.
is it possible to use 16 / s16 lenses on the scarlet x ?
is the pl mount of 35mm lenses the same as the pl mount on 16mm lenses ?
if not: is there any adapter which can enable this ?
if the answer is yes: which part of the sensor will be covered by 16mm lenses ? 2k or 3k ?
i'm asking this, because i'm doing wide angle shots the most of my time, and i need also the higher framerates at 2k and 3k...
thank you, norbert
thank you, norbert
