Häakon
Suggestion for a possible solution
I’m not an engineer, but I would guess that RGB 720p/120fps is actually a higher data rate than RGB 1080p/60fps. Jim has stated that RGB 720p/120 or 2k RC RAW/96fps is an either/or situation – both are not possible. There seems to be many people OK with losing 720p/120 to gain 2k/96fps, but they also want to keep 1080p/60. If 1080p/60 is a lower data rate than 720p/120, it just may be technically possible to finalize the specifications with 2k/96fps and 1080p/60 and still keep within the sensor limits using VBR (variable bit rate) manipulation...
...I think RGB 1080p is very important to keep in the camera specs for many of the reasons myself and others have posted on the “1080p and 720p…losers” thread. I'm fishing for a compromise that would allow 2k/96 and 1080p/60 to both be in the final specifications.
I agree with you completely Gibby; 1080p is essential - aside from instant deliverables, it's the only way (at this time, anyway) to keep (onboard) 60fps alive from the full 4K sensor. That's a big deal to many people here.
However, (and I'm not an engineer by any means possible - so take this post with a grain of salt), I would speculate that it's not the bandwidth of the recorded frame that's the problem (after all, you wouldn't be recording 720p/120 and 2K/96 at the same time) but just space on the FPGA itself for coding instructions/format choices. In other words, while the sensor is potentially capable of doing 96fps at 2K AND 60fps in 1080p RGB AND 120fps in 720p RGB, there may not be room on the FPGA to embed and deal with all of the conversion instructions. As long as you have a fast enough pipeline (CF card, hard drive, whatever), the bandwidth isn't the issue. That's how I'm interpreting it, anyway.
And you're right, we haven't heard back yet if nixing 720/120p will still allow the provision for 1080/60p - which is the critical question. I think if enabling 2K/96p is possible - but only at the expense of both 720 AND 1080 - many people will have a problem with that. Here's hoping to hear back from RED soon!
