1000FPS 4K Red Dragon
  • Hell yes!
    Votes: 267 68.1%
  • No, high FPS is overrated
    Votes: 28 7.1%
  • No, too expensive
    Votes: 97 24.7%
  • Total voters
    392
One of the many reasons why super slow-motion in a RED camera form factor would be amazing: https://vimeo.com/25037759
Its not the specs that sell cameras. Its people doing creative work with them that inspires others.
If the iPhone shoots 120fps, shouldn't a future RED be doing 1000+, hell yea.
i really hope red makes this!
I would rent a camera if I needed 4k 1000fps, but I'd love to see (and use often) 500fps 4k burst mode on my Epic.
One question, why can audio not be recorded at 120fps or even 240fps? iPhone can do 120fps with audio yada yada yada..
For me, 500fps burst with audio would be a dream come true
Please!
Red I hope your going to make a burst mode or a dedicated high speed camera! I would love either!!!
Also recording off speed audio would be sick!
And a option to save 1:2 or uncompressed data. Would hate to see high fps stuff get trashed due to high redcode compression.
A bit of a tradeoff there... 4k 1000fps uncompressed fills 64gb in less than 5 seconds, not sure they'd be able to build a camera that could on-the-fly compress 4k at those frame rates - but if they did it would be unique.
I was thinking to buy 2 Phantoms for that reason but I REALLY wish Red finds a way to upgrade the hardware so with few thousands we could upgrade our Reds to 1000fps. I hope also Red will offer choices because some might be happy with 600fps, of course in the max res and not in the lowest compression. Until then... Twixtor is ok.
+2, I can't imagine how this will look in 3D:
https://www.youtube.com/watch?v=duNNOOmf_tk
Not sure how to answer the poll…
I don't have enough demand from clients to own a high-speed specific 1000fps camera. If it can do everything the current Dragon can do, plus offer up to 1000fps @ 4K, then hell yes, I would buy it!
As a natural history shooter my Epic almost never shoots real time. Producers almost always want the max that the camera can do. If you could make the chip clean a 2000iso even if it had to be FF 35mm it would be a huge step up of ambient light shooting. The phantom has a base ISO of 250 in color mode which just doesn't cut it when you need a 2000th of a second to maintain a 180deg shutter.
Voted - bring it on I would buy one.
OK. How it looks with burst mode for Epic X and Dragons? Will be there sometimes? Can we look forward to let's say 5K in 300fps for about 10 seconds? I'm just asking :-)
The Flex4K is a bit odd with it's ratings... I don't think it's apples to apples to say EI250 is the same as ISO250 (even though Vision Research tells us to do it). I just received all the odds and ends for mine (had to have some custom cables made) so I grabbed some shots today. Here's a shot taken in an indoor room with the lights off (ambient light from a partially unshaded window... dark enough that I generally turn lights on when someone stops by... but I like it on the dark side when I'm working.
This shot was 16ms at EI 250.
This shot was 1ms at EI 250
This image is 1ms at EI 4000
You can click to go to flickr for the full sized files.. unedited other than converted to 8 bit png for upload. You can definitely see some noise in the EI4000 shot... but it seems very modest compared to what I'd get from any of my other cameras if they were set to "ISO 4000". It'd be trivial to clean up in post. I duplicated your desired settings (500us) and had to push the max EI to reach it (12500). In this shot you can definitely see noise, but again the light level is quite low compared to what you'd see outside. This is essentially an indoor ambient light shot (not conditions you'd typically have for a 1000FPS shot).
