@ Terry
crop factor is a relative term, if you are a still photographer and feel the need to always relate it back to what you are comfortable with which is full frame in your case then do so but keep in mind that full frame has nothing to do with the original question.
The original post was about an 8-16 zoom on a scarlet. My post 13 used the term crop factor in order to answer the original question which was 35mm lenses on a 2/3.
ie 2.5 crop factor when relating between 2/3 and s35
tell me ... why do you feel the need to relate back to still photography as your baseline standard when this is a cinematography forum?
RED has not made a full frame camera, and in there immediate upcoming cameras everything is s35 and 2/3 not full frame
in fact the only point of reference you have regarding modern cinematography is to the 5DMark2.
