- Thread starter
- #421
Jannard
Red Leader
- Dec 28, 2006
Great idea Jim, thanks.
Can We talk a bit about the difference in "compression" although neither are released yet (save M-X)
I understand both use Wavelet compression... the cost difference (to me) seem relative to Arri sticking with the belief (up for debate) that LESS compression is
good... wherein the goal is 2 to 1.
I say this because I get push back a lot on RED's 10-1 compression scheme... which I then counter with
1. Differentiating SOPHISTICATED compression (wavelet) versus MPEG. (easy thanks to Graeme's explanations)
what is NOT easy is differentiating RED compression to ARRI's Compression other than to say its a battle of "MATHLETES"
I will say that the increased cost of the ARRI is perceived to be (whether accurate or not) more expensive due to less compression.
thoughts? thanks!
We believe that the RED images now stand up to any camera... and you can record to a compact flash card. Pretty convenient. We also know that less compressed options are needed... which is why EPIC will have REDCODE 250. With us, you can have it both ways. Not sure anyone else has a program like this one...
Jim
