REDCINE-X Build 183...
Jannard
Red Leader
Now up...
http://reduser.net/forum/showthread.php?t=40067&page=2
RCX Build 183
Audio:
Exporting audio channels no longer requires channels with a lower index be preset in the file.
Automatic Audio Sync algorithm improved.
Exporting:
Export option to overwrite or to add "_S###" to the file name.
Avid MXF export has been added to windows.
Black Frames bug fix
Timecode metadata fix
Burn-In text improved
Burn-In Timecode fix
Open Exr added (preliminary)
16bit DPX added (preliminary)
Gui:
Video player improvements
Ability to save and load presets to/from separate files
Reset in/out points added - Option click the in/out point buttons when a clip is in the video player.
Option-clicking a clip's resize handle in the timeline will also reset in/out points.
Detail window green box will now go away when the detail window is closed.
LUA scripting added to windows.
Framing and Framing Presets windows are now a single window.
The Sharpness and Denoise sliders were moved from the Detail Tool to the Image Tool.
The Debayer slider on the Detail Tool was removed.
External audio match information for each clip is now saved in project files.
RED Rocket™™™ Monitor Out:
Timecode added to monitor output. Edge/Abs/Timeline
Color Science:
White balance tweak for Sodium Vapor lights
Windows features not enabled:
Audio playback
openEXR support
Jim- The above link may be broken...
Might just be me, but I can't seem to link via the above link... I know where to get it, and am downloading... just thought you might like to know.
Oh.
And Thanks, BTW !! I was just wondering if we'd get a new rev soon...
-CK
Jim.......the Link needs to be fixed.
Can someone please tell me what I may be doing wrong? When I put my clips in a timeline and go to export all the clips to QT I setup my export as follows;
- Choosing QT
- Set my Debayer settings to FULL
- in OUTPUT LOCATION - I choose "Output with Clip Filename to selected folder"
- I select a specific folder and click "Sub-folder per clip"
I want my quicktime files to be in seperate folders hence the "Sub-Folder per clip" checked box. Also, I want my file names from the source R3D to be represented in the individual exported clips. But when I hit export it is asking me to name the file which i don't want to do ( I want the app to know each clips filenames) and its exporting all the clips in the timeline to one single file.
Its probably me but I would assume that the export settings I have chose would grant me what I'm looking for but no luck. Any help would be appreciated.
The win release is crashing like the previous version. It loads fine, but when I drop in a clip and play, it freezes. I'm getting an Opengl32.dll problem. I guess it's because I have an Nvidia Quadro FX3500? What are the approved video cards?
i'm able to export without any problems except when exporting to quicktime no matter the codec. It would either crash the redexport.exe or redcine-x itself. Running Windows XP on Dell XPS M1530. Didnt have this problem with build 104.
Now up...
http://www.reduser.net/forum/showthr...t=40067&page=2
RCX Build 183
Audio:
Exporting:
Gui:
RED Rocket™™™™ Monitor Out:
Color Science:
Audio playback
openEXR support
Hmm, no posts in a couple days, thought you guys took some time off - HA!
Downloading now. thanks!
- Choosing QT
Hey Mike,
You need to select all your clips on the timeline (cmd a) & then click export... you'll get the desired result!
:cheers2:
Try updating your drivers to the latest on nvidia's site.
The 3500 came out about 4 years ago so there could be something RCX is doing that's not supported on that card. Do you have a newer card you can try?
Deanan, very strange behaviour here: RCX 183 Windows 7, works very fast and well with the Red Reel original R3d I downloaded, but not at all with original R3d files shot with my cam and build 30.4.1 Mysterium non X sensor. Very slow with older R3d (build 21...) and freezes always when I try to export quicktimes.
Do you think its something wrong with my cam? Did you check the LOG file?
Thank you,
Marc
I'm getting Red Export.exe errors, and when I use a setting other than RedSpace or RedGamma and then render RCX 158 crashes.
But the files appear to have rendered to Avid MXF 1080.23.976 DNXcel 36 OK when I stay in RedSpace and RedGamma rather than selecting Rec709...but I'm having no luck being able to get them into my Symphony Nitris to check these files to see if picture and sound is any good. My Console says "[ Plugin Name = MXF Plug-in Vendor Name = Avid Technology, Inc. Version = 1.0 ] could not process J:\Cuda tests\a003_c001_0313ep\A003_C001A011FA4EAA1.mxf"
I saw in the latest download folder something called AVX_plugins2...and a plugin called AvidMediaToolkit -is that something I have to add into the AVX plugins directory for Avid?
