- Thread starter
- #21
Gunleik Groven
REDuser Sponsor
Thanks Gunleik, I was thinking about multiple secondaries.
Me, too...
You can add a keyer/tracker/mask, add your color-tools, do your correction, add another under that, etc. That way you'll have multiple secondaries.
The ideal situation (as to the problems I see) is that the secondaries indeed took their info from RAW (after the redroom) and gave you access to that data (so you could recover highlights and lowlights in the secondaries).
As it works it is worst of two worlds. You pull your keys from the camera-metadata, and do your correction from the image out of the primary...
Uli... I couldn't find the cow-thread you mentioned...
