toke lahti
- Sep 24, 2007
All comparison I have talked about is always assuming the same specs: pixel size, etc.Not necessarily, sensor size has nothing to do with how Red designed the active pixel sites or circuitry in each sensor. Even though it too does not tell the whole story, pixel density is the first factor to start looking at. And even beyond that, within the pixel density, how much of that area is active and how much is supportive circuitry. If they used the same exact circuitry in all their sensors, they could be all exactly sensitive, but I'd argue that the larger the sensor, the more issues with voltage drop and on chip variation so you could lose some sensitivity across the entire array if you were stringent enough in your yield selection. Which is why it makes sense to me that the larger sensors are so much more expensive.
AFAIK, MX will have to types 3.2µm pixel size and 5.4µm.
I guess that these 2 are technically on same level so when the latter has 2.8 times larger pixels, it should also be 2.8 f-stops more sensitive.
They could also use exactly the same design for different sized sensors.
And adjust the pixel size or resolution...
There are of course always minor differences, but the big thing is that with Scarlet, we could use bigger sensor than what we have used for decades in eng, efp, event & documentary (2/3"), but S35 is just overkill and therefore waste of money.
But of course I'm trying to figure out the optimal Scarlet just because I'm poor.
Those who have money, just go and pick up FF Epic and shoot whatever with whatever lenses happily ever after.
