Mark L. Pederson
REDuser Sponsor
Great post about MX thank you!
spoken by a guy who was been shooting on a frozen lake and underwater with MX for weeks ... (PatC is secretly one of Offhollywood's RED TECH/DIT's)
Well, certainly 3200 ASA is usable, as you see, but it's a little like underexposing film and pushing it, in that you reduce your margin for exposure error. In other words, you don't have as much flexibility to color-correct your images before you fall off of a cliff. So it depends on how sure you are of exposing consistently and balancing your colors consistently.
I'm going to stick to 1600 ASA as my upper limit but 2000 ASA is certainly workable. Yes, you can always crush the blacks to hide some of the noise, but often the reason you are shooting at such high ASA ratings is to capture natural low-level ambiance at night so you may loathe to lose some of that detail by crushing the blacks.
I did a test where I overexposed a face by three-stops to see how it looked, and it was between 400 and 800 ASA where three-stops over didn't having any clipped area on the caucasian skin tone I was shooting. At 400 ASA, the brightest spots of the skin were clipping.
So I'm probably going to try 500 ASA for day exterior work until it gets darker, then shoot mostly at 800 ASA until I get into a low-light situation where 1000 to 1600 ASA would be fine. It's an amazing improvement over the old sensor where even shooting at 500 ASA in 3200K could give you some distracting blue noise if you weren't careful to keep your blacks pushed down a bit. Even at 3200 ASA at 32K on the new sensor, the noise pattern is fairly tight and even, without a pattern of blue chunky noise appearing in the image.
These look very similar to the shots offhollywood recorded in New York.
Now I'm totally confused. Maybe I just don't get how ASA/ISO works completely, but that seems counter intuitive to me. If you're clipping at 400 ASA, wouldn't you want to go DOWN to 320? Or is there some kind of change in DR with ISO adjustments? Why are you increasing to 500 ASA for your daytime exteriors? Is there some kind of advantage in contrast?
