Jonathan Stevenson
I wanted to see if I could get a bit of advice in regards to gyro stabilization, as products like Kenyon gyros and such are very new to me. I am shooting a feature next year and was hoping to learn more about units such as this before I start testing with them.
It is my understanding that with a gyro unit, such as a Kenyon KS-6 or KS-8, are generally used as compliments to a steadicam system, making the rig much more solid to avoid that "floaty" look. But I've also heard you can attach these units to a small, lightweight camera such as an HVX200 or the upcoming Scarlets and Epics and use them as an alternative to a steadicam system. Is this correct? I think I heard somewhere that they used a gyro rig in Slumdog Millionaire. They simply attached the gyro unit directly to the bottom of the camera and were able to achieve near-steadicam stability because of the camera's size and weight (similar to Scarlet and Epic size I think). Does this sound right? Or are gyro units only good for adding additional stability to a steadicam. The only pictures I see on google are with gyros attached to some kind of secondary rig.
The reason I ask is that it seems with a stripped down, lightweight Scarlet with a gyro strapped to it, you could pull of some serious Neveldine/Taylor type stuff, minus the vomit-inducing shaky-cam. I'd love anyone's advice or help. I was checking out Constantine's running rig products and they seem awesome, but are all geared towards shoulder mounts. What if I just want to hold the camera by a top handle and run with the thing!? :thumbup:
