David Mullen ASC
Moderator
Ahhhh, so the SD camera merely stretched the pixels horizontally rather than squeeze the image vertically - gotcha.
There were some SD cameras with 4x3 sensors that basically recorded a slightly smaller 4x3 area of the sensor when in 4x3 mode, and used the full width of the sensor, but less of the height, when in 16x9 mode. Think of the 4x3 and 16x9 frames overlaid in a cross-shape sitting inside a larger 4x3 sensor. The idea was the the 4x3 and 16x9 images would both use about the same number of photosites on the sensor for equal quality, but it did mean that you weren't getting the best possible 4x3 image that the sensor could in theory create.
