Tony Lorentzen
RED doesn't say that you void the warranty if you choose to disassemble and then reassemble your own mount, such as if you wish to check the torque on the bolts or adjust centering.
Can someone from RED confirm that performing this task (assuring the mount-bolts are adequately fastened) is okay and will not void the warranty? I know of at least two cameras where the mount has been loose after the upgrade program and I have been thinking about checking my own camera to make sure (but haven't because I've been afraid to for that exact reason).
