Scarlet Audio
Sterling Wescott
Any recommendations on a good mic for scarlet?
I don't plan on buying an I/O module until the ff35 scarlet comes out, so i want a mic that will function with just the scarlet brain.
Scarlet audio
Scarlet audio
What sort of ports do we get on the 2/3 scarlet, I'm assuming no XLR?
One 3.5 mm "stereo" jack for each of two mono microphone inputs (use of a "stereo" jack allows balanced audio input)
If you want XLR inputs, then two additional audio channels (for a total of 4) are available with either of the I/O Modules.
All analog audio inputs include a pre-amp and signal limiter, and are digitized and recorded at 24-bit depth and 48KHz.
Hi Stuart,
A couple of thoughts:
It would be great if the 3.5mm inputs were threaded for locking. No kit component wears out faster than a standard 3.5mm input jack.
Four channel audio input is a desireable feature in the documentary run and gun world....two channels for stereo ambience and another two for a stereo mic on a boom pole or for two RFs. It would be nice if there was a simple module with just two XLR inputs. The standard I/O module has much more than is needed for just audio and is twice as long (and perhaps twice as heavy and expensive) as needed.
I assume you could use a 3.5 to XLRF adapter cable as well, right? what does that do to the quality?
That doesn't affect quality at all...not nearly as much as 3.5mm female jacks that lose their connective integrity through jiggling and sideways pressure on the 3.5 male.
David
Sterling:
There is no mic out there specific to any camera out there. It's like asking what camera will go good with my Sound Devices 788T 12-track recorder. The two aren't related. The question is what audio you want to record with what you're shooting - from there you choose a mic. In any case, mic choice is the generally in the realm of the guy or gal in charge of the other half of your film: the production mixer!
A.
Will the fixed-lens scarlet accept an XLR adapter as well?
No reason why not. For on camera mics a simple 3.5mm to XLR cable is all that is needed. Mountable adapter would provide strain relief and more secure connection for off camera mics.
I'm confused how in #6 of the Scarlet announcements it says that there's 48v phantom power... but in this post, we're told that there is only a 3.5mm stereo port. So... no phantom on that port, are you referring to the I/O modules?
Also, can anyone find a description of exactly what is on each module (pro vs basic)?
that also confused me, i was informed in another thread that the scarlet fixed comes with two 3.5 inputs and they provide phantom power
anything more??? ... ONE for each of TWO ... :cursing:
Electrically the ports (there's two of them) on the front of the brains are exactly the same as an XLR cable - it's just in a different connector. Phantom power is no problem assuming you have the right cable or adaptor.
If you're really interested in the details, it provides a balanced input through a three pin plug generally used for stereo. Instead of putting a ground on one segment of the pin and two positive signal channels through the others like a stereo input though, it instead has ground, negative and positive segments that connect to the ground, negative and positive pins of an XLR cable on the other end.
Take a look at the Wiki page for more details.
It's hard to understand why they would put phantom power on the RED as there will be phantom power on the Production Mixer's mixer. Let him or her worry about phantom power, etc.
