Lee Saxon
Let me pull focus with turntables, or I will find a way to sue you!
ROFL
Seconded.
ROFL
Are you asking if Red will rehouse it and offer it as a optional zoom lens for the 2/3" interchangeable?
(Just want to be totally clear on this, since the 8X Fixed is a special beast at a special price, it's a little different from the rest of the DSMC system.)
The price on the 8X Fixed is so good (even with the increase) I just want to be sure of this point - all the included accessories are the same as the ones I'd buy if I was equipping an interchangeable lens model, right? No issues I'd have to deal with when I upgrade the body and lens?
[FONT="]Per Ed and Brian's exchange, are we assuming that 28MB/sec is the data rate floor. Can it be lower?
I see the Red Drive available for $900. Since it holds 640 GB, looks like one might be able to get 380.95 minutes (6.3 hours) off of this drive at 28MB/sec. Will this Red Drive support faster frame rates? Is this a viable solution[/FONT][FONT="]?[/FONT]
REDCODE records at a fairly consistent bitrate no matter what size frame you have chosen or framerate. This is why the increase to REDCODE 36 (from 28) most obviously benefitted higher framerate shooting (more bits per frame.)
Yes, a Red Drive will work with Scarlet. Yes it is fast enough to record REDCODE 28 (and also REDCODE 36). You can choose whatever resolution and framerate you want for that bitrate.
I'd like to see a three-lens turret option on the Scarlet 2/3" that accepts the mini-primes. This shouldn't interfere with the board stack, right? It probably wouldn't interfere with the cooling system duct. Anyway, I think it would be a desirable option.
heh heh heh..... turrets....
But can we record redcode 42 with this and sustain 120 fps? thats what im wondering because id much rather have just one drive then piles of cf cards.
Yeah, the old 16mm Bell and Howell 70-D (indestructable tank) wind-up cameras, which I used in college back in the late 70's/early 80's, had turrets on them as well.mini-turret, you complete me.
I'm quite fond of my '67 turret-front crank-equipped Konvas:
http://www.flickr.com/photos/r_jackson/3340289653/
