RELEASED: Build 21 Firmware (v21.3.2) - Release Build
I could only find Build 21.3.1 on the server. Anyone have the link for 21.3.2? Or when will it be back up?
I don't see this on the website. I see Release v20.1.6 and Beta v21.3.1
Default settings - REDCODE 36 or 28?
I've noticed the default for Build 21.3.2 is Redcode 28. If memory serves, it was always Redcode 36 before. Any reason for the change?
Hi Elsie, as Jarred mentioned, we have pulled Build 21 v21.3.2 off the web site in order to check some settings.
However this comment isn't accurate. The default for the camera after upgrade to any of the recent builds is REDCODE 36, 4K 2:1 and 23.98.
So can you re-check that? If you believe that it's still true for your camera, please send me a P.M and we can walk through your scenario.
On the Black Shading question - no advantage, I usually do it at REDCODE 36.
Sorry Stuart, but I'm shooting 21.3.2 right now.
My setup is 4K 2:1 RC36 23.98...
No problem at all for now...
should I downgrade?
Could you PM me with possible problems details?
Waiting a feedback...
Best Regards
Build 21 v21.3.2
Build 21 v21.3.2
Hi Raphael, if you are already using B21 v21.3.2, there is no need to downgrade.
We know that there are multiple projects shooting on this build without any issues.
Yikes!!! It's happened! I have lost my mind. I reinstalled the firmware just to see and it does indeed default to Redcode 36.
Just Settings issues? Right?
Jarred?
Build 21 Problems
Build 21 Problems
I had downloaded and installed the RELEASE version of Build 21 and had no major issues on our first day of testing (other than the 1080P playback issue--see my other post) but today as we're prepping for a 3-day commercial the camera is NOT happy. Locking up at the drop of a hat. Monitor and LCD showing 2 different aspect ratios (a first for us). Retreating back to Build 20...
Sorry Stuart...i didn't see it. Refreshed now.
My project is on of those. No problem at all.
Shooting a Feature for Television based on " Machado de Assis" novel " Uns Braços".
I will post some frames as soon as possible.
Thank you.
Best Regards
Build 21 v21.3.2
Build 21 v21.3.2
Yes, but it's more of a precautionary measure while we understand a couple of issues that have been brought up.
There are many cameras running 21.3.2, and versions of Build 21 have been in use for more than 45 days without issue.
Thank you for your support Stuart... we all appreciate that.
Redcine and v21.3.2
Redcine and v21.3.2
There will not be support for B21 in REDCINE... all current and future development will be in REDCINE-X.
Jarred, is there any known issue with running v21.3.2 in Redcine for say a 2K 16x9 image? Can't get my head around RedCine-X yet (Windows) but updated the camera build before it was pulled.
Ran a quick test and it seems to behave as I expect it would in Redcine v20.0
Can someone explain what does support for S4i connector means? I have build 21, but can not enable/see any data on the screen.
