Hey guys, I'm not a fcp guy, but I'm planning on doing a retransfer of my red footage to dpx files in redcine in order to reconform my timeline in after effects, and output for a color pass in color.
The issue I am having is that I know nothing about dpx files. Isn't dpx the same as cineon which is a 4:3 aspect ratio? how does it handle 16x9 footage? Any thoughts as to what the optimum settings are to output from redcine? Any help would be appreciated.
On a side note... Is it possible making a dpx file from an uncompressed hd quicktime? If I did that would it be losing any information/resolution? My final output will be hdcam. If I could simply render out a dpx file from my uncompressed hd timeline, it would make my life much easier. Thanks in advance.
*edit* I think I found an answer to my second question in that if I make a dpx from the hd file, all the damage is already done to the picture(ie whites are clipped, and blacks are crushed) so even if I made a dpx from the hd file, the damage is already done in the conversion to hd. Does that sound correct?.
