Tim Hole
Am looking for a current or soon to be released Motherboard for an i7 8-Core 3.06GHz Processor. Can't afford the leap to 3.33GHz.
Any ideas on a high performance mobo?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131378
very few at the moment. more will come out in the next 3-6 months
it usually take a bit, apple kind of locks down the patent for a bit with intel cause they got deals left and right, and pc hardware CAN release it but there is usually a lag time, the i7 8 cores for mac are pretty new, i remember when 8 core last gen intel came out it was a decent lag time before we started seeing skulltrails and other mobos that supported 8 cores and gave you all the pci express ports and so on that match a mac.
what are your functions for this system? vfx work? 3d? Editing? the mobo i showed you is just kind of a initial mobo for the next generation of ones. it may not be tricked out enough depending on what you wanna do.
You might consider the Xeon version. http://www.newegg.com/Product/Product.aspx?Item=N82E16813182176&cm_re=x8dah-_-13-182-176-_-Product
This is the MB I just purchased. It has all PCIe slots. 2 x 16, 4 x 8 and 1 x 4.
I am going to assemble it all this weekend. I went with 2.8 GHz CPUs, 24 GBs of tripple channel RAM, REDRocket, etc...
so you basically wanna do a little bit of everything. so your gonna need a bigger power house if u really wanna see substantial differences.
xeon will be the way to go as it does sheer mathematical computations for better then ur normal processor brand.
don't forget video card if ur doing 3d rendering, that will take advantage of ur GPU more then any other piece of software, also if u wanna do heavy compositing. diving into the FX series of video cards will be helpful.
you'll definetely wanna hold out for a mobo that has plenty of pci express 16 slots so that all your cards will work at max efficiency. you can also look into magma express box posted by sanjin a few days ago, it will let u do more if u want a all in one system.
lots of ram!
windows 7
and fast raided disk arrays. if you want a power house that's a way to go.
and another question, y not trick out a mac? all these things will cost almost as much...
and side note, red dwarf is one of my favorite shows of all time![]()
