Tim Sutherland
I think an important consideration in ETTR is to make the decision by scene, which most likely means that you TEST the camera before shooting it, just like you would if you've never shot Kodak Vision 3 before.
The reason I think it's important per scene, or maybe per dynamic range envirnonment, is that you can sometimes be opening up the iris 1/3 of a stop to fill the histogram and then close it back down for the reverse, if you are matching shots. Now you have DOF changes and other considerations.
I think this is a decent hybrid between the 'old' ISO based system, and the histogram reading situation, because you can use the histogram in your tests, and say, for this 2pm daylight exterior, we are going to rate the camera at 500ISO and fill in the shadows a bit, in order to keep the skys blue. That way you have a base exposure setting to help with continuity of lensing, etc.
I think that's one of the big differences between using a histogram for stills and a histogram for motion. In motion, a lot of times you make aesthetic choices with the lens, shutter speed, etc, and then you work the lighting/DR (as much as you can control it) around that (although, you can't just pluck numbers out of the air, it requires testing). This allows you to have that continuity in a scene, especially matching elements, that are sometimes (often?) not necessary when exposing for digital stills.
Hopefully my point is clear here.
