I'm currently confronted with a very troubling problem, so any advice would be greatly appreciated.
I'm currently working as a Data Manager on a feature which has been shooting with the RED 16GB Compact Flash cards. The first 10 days of the shoot went without issue, but the last 3 days have been a major headache.
It all started when we began shooting with 2 cameras. During playback on my 8 core Mac Pro I started noticing drop frames from B Cam (green flashes), and soon after the R3D's from A Cam were cutting off short of the actual take. We checked everything on both cameras (settings, builds, etc...) and found them to be identical. They both had the improved CF writers, and the four 16 GB CF cards we are using had been upgraded with the new firmware.
We also have RED 8GB CF cards as a well as a RED Drive, and neither of these have caused any problem. It is only with the 16GB cards. After first thinking it was a camera issue, we finally came to the conclusion that it was actually my FireWire 800 Compactflash Reader (Calumet) that was causing the problems.
Using R3D Data Manager, the problems would first arise with a bad checksum verification. Upon playback of the clips listed as unable to verify, these frame drops and or clips cutting off early would be detected. Finally, after trying the same download to my laptop (15 MacBook Pro) using a simple USB CF Reader, one of the problematic 16GB cards downloaded perfectly, without any checksum errors. The clips played back without any errors. This seemed to be pretty clear cut and dry, my FireWire 800 reader was to blame.
Our only good fortune this whole time has been our ability to recover any problematic cards using R3D Data Manager's "R3D File Recovery". So we haven't actually lost anything.
The odd thing was that we had shot for 10 days using nothing but the 16GB cards and my FireWire 800 reader without a single issue. However, it seemed logical the reader was to blame, and so I started using the SanDisk reader our D.P. owns and had used for 6 months with the same 16GB cards without issue.
Everything seemed fine, and today we shot several Rolls onto every 16GB card without a problem, but now the problem has come back. Three 16GB cards in a row (all from A Cam) showed checksum errors, and playback of these clips confirmed we still had a problem. Interestingly, one of the cards that showed drop frames and cut out early on my desktop, did not show the drop frames when downloaded to my laptop using my simple USB reader (although the R3D still cut out early).
This seems like a problem on my end, but the fact that multiple readers have now shown the same problem, and that for 10 days straight everything worked perfectly, and only when we went to a two camera setup did problems emerge, leaves me scratching my head.
I can't pin point the problem with any certainty. The D.P. contacted a friend who had the same sort of problems and it was concluded that the CF Writer on the RED ONE Camera was bad, and once replaced everything worked fine. So maybe it has to do with our A Camera, or maybe something odd is happening while downloading the cards, or perhaps the cards themselves are going bad, I'm just not sure.
Again, the good thing is we haven't actually lost anything, and we have our RED Drive and 8 GB CF Cards which work just fine. But we prefer shooting to the 16 GB cards, so solving this problem is a priority.
Any suggestions?
Any suggestions?
