Joseph S.
- Jul 2, 2009
- Santa Monica
- cinespeed.com
I found my favorite case set up. These Pelican 1500 cases with the tear-out foams are pretty cool.
But I believe that there is a special spray which you can apply once you have cut the foam out to your liking, the spray is to prevent the foam pieces to come apart, but it should also prevent any particles from been released, this second part not sure at all.
ciao
Is this what you are talking about?
http://www.studiodepot.com/store/index.cgi?cmd=view_item&parent=&id=62789
I used to use the Pelican cases exclusively, now I have switched to the Storm, mostly because of the much better latch design and the dividers.
I must say that I did also used extensively the Pick n' pluck foam inserts, but then stopped completely using them as they produce very fine particles which enter the lens elements and are a B%#@! to clean, so no more Pick n' pluck foam for any electronics, especially lenses and Cameras.
ciao
Can you tell me about the LED lights pictured... what are they??? What is your application with them.
