Frank Weeks
I think I've tried to make that clear throughout this thread. But I've also said that because the Series 11 is basically an HD video monitor - and designed as such - that as long as you disable all of the automatic stuff, a basic setup using something as simple as the Blu Ray discs that are sold for home theater setup purposes can get you far more than close enough for most eyes that don't happen to belong to a professional colorist. And even professional colorists often won't be able to see a significant difference. If you have scopes connected to the same feed the monitor is getting (in order to confirm that what you're looking at makes sense), and the room lighting is reasonable for color work, my feeling is that it will likely provide a very acceptable image 95% of the time - and certainly something that will look reasonably similar on any other monitor it's likely to be seen on. That may not make it technically perfect, but it happens to be true.
Thanks Mike
I will search out that DVD. With Primes, Rocket, Null and LCD up for payment, the DVD is about all we can afford
Thanks for the info
