Nicholas Costaras
Hi
I just tested out the new Vegas 9 with RED. You can literally edit in 4K...if your machine can handle it. You can also drop the .R3D file onto the timeline. What's also great is that instead of using proxy files you can just set your vegas project into a smaller more managable project 720p and get a smoother play back. So no more proxy files....yay. You can place a colour effect on the timeline clip or any pluggin and still manipulate the RAW file values and see the results immediately. Quite an impressive workflow if you ask me. Now...the bad so far...I'm sure there'll be more as I start to play with it properly. The default colour is more "purply" than the original .R3D. I actually called up the file from RedCine and Vegas and the results are drastically different. One awesome thing though is that if you are editing a 2K project you can crop the original 4k on the timeline. No painful import export. So in terms of workflow...this would be incredible to be able to manipulate any size RED file on anytimeline and access the RAW data and then still adjusting the RAW data while checking it directly on your time line with all the your added effects on.
The beauty about the 4K option is that you actually have a 4k option. You could literally set your project to 720. Edit the whole thing and when your ready change it to 4K and push out the project as needed. Vegas also cleverly handles any file size on any time line. i.e. 4K on DV pal. The crap thing about Vegas unfortunalty is that is struggles to downscale...If you take a HDV project and render it out to a smaller resolution it really comes out squashes small squares out instead of good clean FCP quality...it seems a little dodge. Like I said early days yet...Firstly if I could figure out how to get the colour exact...or maybe they could even release a patch. Anyways, I could post some screen shots so you can see what i talking about, but that is also to assume that anyone would care to use Vegas. I use FCP and Vegas and honestly prefer the speed of vegas literally 4 times faster to edit that FCP but like the quality of image that FCP delivers...so this is my journey.
