PL Mount 11-16mm f2.8 Prototype, Manual Iris
If I understand everything about the Tokina conversion that has been said, the iris was re-worked to allow for a longer rotation and better manual operation. Perhaps it's possible for the aperture to open up just a bit more under these circumstances. So it could be any combination of these things, or so I would think, that leads to the lens being T2.8.
This is partially true. We did re-mechanize the aperture linkage, effectively extending the rotation to allow for a manual aperture ring with legible engravings. Although, we did not increase the diameter of the aperture at full open. As most people would, we assumed that the lens would read a t-stop of T3. I'm going to check the lens on several t-stop benches just to be completely sure... But most people around here use the Kish Optics T-stop bench, which my father built.. I'm pretty sure they will give the same reading.
Shawn,
F-stop is a calculation based on spec numbers. Aperture size and focal length... etc..
T-Stop is a reading of the light actually passing though the lens, a measured amount.
T-stop , in my opinion, is more accurate since it is physically measured with the lens itself.
F-stop does not account for poor coatings or light lost in lenses with many groups.
I always assume that manufacturers account for this sort of thing.
But according to the definition of what "f-stop" is, they don't have to.
Okay, your description is exactly what I thought and described.
So you're saying that the Tokina "f stop" is actually a T stop since they already accomodated for light loss?
Not really... What Im saying is when Tokina did the math and calculated the f-stop, they probably didnt realize that their glass would produce a reading with the same number.
I highly doubt they did that on purpose. T-stop readings aren't important to still lens manufacturers. They just want to label the lens with the lowest f-stop possible. That's why they always label with f-stop, because its a number that is equated, not measured.
Paul,
good news and bad news...
Yes, you are on the first batch.
But we still have another 2 weeks of assembly left.
My time is being consumed by CineGear Expo this weekend, but after that, I'll be pounding them out.
no problem, as long as I am in the first batch, how many orders didja get?
one other thing...can I get that pinstripped?
could I have mine engraved in Roman numerals please....
We already did yours in Comic Sans... Bold.
We also had names lined up for every lens instead of serial numbers.
But it turns out the engraver simply pushes a button to sequence serial numbers... Saves a lot of time and money.
So the names will only be known by those who disassemble the lenses. Or if you ask, I can tell you... ;)
Sorry, my mistake. It was supposed to be a linked image.
I tried to add myself in the list for the 11mm-16mm by emailing Matthew Duclos two days ago but didn't receive any reply from him yet.
Anybody knows what's going on with the 11-16 project?
Very much alive - I was at the Duclos shop yesterday and the workbench was covered with 11-16's being assembled and tested.
You should just call them... +1 (818) 346-9505
Matt Uhry
www.mattuhry.com
Miltos,
What is the email address you used to add yourself to the list?
I will confirm it with you.
Just so everyone here knows, when you email me to be added to the 11-16mm list, it's automatic. I don't reply to the email unless there is a question or a concern.
I assure you the project is in full swing.
Hi Miltos,
You have been added to the list for the second batch of 11-16's and you will be receiving an update when we begin production of the second batch.
Thanks!
soon yes? not that I am excited about this lens or anything....
