Scott Webster
- Dec 28, 2006
- New Zealand
- www.rocketrentals.com
On behalf of skim readers everywhere
Red Alert companion Version of Build 20 is the only app that can take advantage of the new Color Science. I assume this includes Red Rushes?
By updated I read this to be new versions to be released.
Old footage can processed to take advantage of the new Color Science but only through Red Alert Build 20.
Note: Download the companion version of RED Alert! (Build 20, Version 20.0.1 or later). TIFF, DPX and standalone QuickTime files rendered out of RED Alert! from Build 20 .R3D files will provide consistent color to the camera monitor ports.
Existing version of RED QuickTime Codec, REDCINE and other post production tools should be compatible with Build 20 (Beta) .R3D files and QuickTime Reference files, but these applications will need to be updated before they will reflect the new Color Science. If using any of these tools, it should be expected that camera monitor and RED Alert! colors will not match to these applications, and you should re-white balance prior to performing editing or other color processing.
Note: Use of RED Alert! (Build 20, Version 20.0.1 or later) on pre-Build 20 camera firmware .R3D files can improve color purity and dynamic range and lower blue channel noise, however you should re-white balance prior to performing other color processing.
