Is there upgrade offer for the single license to the multinode version?
Which RSX parameters remains effective in Monkey Extract?
Is it only color space and gamma space choices? What about ISO, Brightness and other parameters?
Hi Ken,
Yes it can transcode to either format.
Quicktimes will contain audio and timecode.
DPX has timecode in the header, and usually also in the file name. DPX doesn't have audio as it's just a still image.
Check out the demo version, which will allow you to test everything out.
Hi Nigel,
I am a registered Monkey Extract user and have downloaded the latest beta to test out your new render with Redcine option. I cannot get the XML to work it always fails to load construct. I am running the latest build of Redcine. Any ideas as to why it is not working?
Specifically, I was wondering how well ME does this with footage shot with a timebase of 29.97/30 fps. Will audio and TC in the Quicktimes be accurate? Same for the TC in the DPX headers?
Ken
Hi,
for the moment i am using a trial version of Monkey extract simply to run some tests on some R3D footage.
i created a CMX3600 EDL in Avid, but when i start the rendering in Monkey to make my DPX files it comes up an error message saying "unable to make new EDL for grading" it also says it is unable to "write" to the destination of my saved EDL.
Does anybody know why this would happen, is it possible for me to use my original EDL in conjunction with the DPXs to conform in FLAME?
any help would be appreciated
Hi Nigel,
I'm having crash after rendering (I think upon creating the XML) on one machine.
Do you know how to fix this, like trashing the preferences, but where are they located?
Thanks in advance.
Kaku
Hi there,
I've got a similar problem like Shaun here below:
I just can't get the "...for_grading.edl" out of Monkey Extract when Converting R3D :willy_nilly:. It seems like ME tries to save the EDL into the same folder the loaded Selection EDL or XML is. So I've tried to put the Selection EDL on the Desktop, the internal HDD, an external HDD end into the network but non of it worked.:sosp:
My Background-Pipeline is:
Rough cut in FCP -> Export EDL -> Conversion by Monkey Extract into Avid DNxHD -> Fine cut in Avid -> Export EDL -> Relink of R3D-Media for Grading in Speedgrade.
Well of course, the problem wouldn't occur if Avid could simply understand the EDL CMX 3600 out of FCP, but that's the main problem :svengo:. I could edit the footage names without a problem so that Avid would relink to the converted media, but every time I import the EDL every clip has a length of 23:59:59:24... :yikes: Now i thought if Avid can't read the FCP-EDL, maybe it could read the EDL created by ME but this little error threw a monkey wrench in my plans - literally :mad2:
Maybe you guys have an idea where the problem is (means: if it's the program or if it is it's user... means: me :willy_nilly
The EDL I've used (coming from FCP) is:
FCP EDL out of hell
Thanks a lot and greetings from the still not very summery Berlin. :frown2:
Frederic Berninger,
OMgraphix / OMstudios, Berlin
