Carlos Prio
what is the frame size in pixels for the 4k Ana mode???
Thanks in advance,
Prio
Thanks in advance,
Prio
Thanks in advance,
Prio
Hopefully someone will chime in with the right answer. Since RED says that the 4K ANA mode is 1.20 : 1 (with a 2X optical squeeze), and if you assume that the recorded height is the same as 4K 16:9 (4096 x 2304), then I'd guess that 4K ANA is 2765 x 2304.
It's 2816 x 2304. It's a bit wider than 1.2:1 because of non-trivial constraints so the little bit extra would need to be cropped off to get to 2.40, 2.39. 2.37 or 2.35:1.
