PL Mount 11-16mm f2.8 Prototype, Manual Iris
My 740iL goes to 155 but the needle can go much farther if you have the Dinan chip . . .
Even if you supply us with a lens, you will still be on the second list.
Unless someone on the first list is willing to give up their spot..? :thumbsup:
give up their spot???? your kidding right? I think you would have an easier time
getting someone to donate a kidney
This is such a wide lens, normal matteboxes might will most likely not work to well. Some clip-on's might work.
Using an "ordinary" 4x4 (DV) Vocas Matte Box I didn't find any vignetting with Tokina 11-16mm
Tokina 11-16mm F/2.8 ASPH. AT-X 116 PRO DX on RED1.
I was up at Chez Duclos yesterday, there was a bunch of Tokinas in the process of getting converted. A few of them were customer lenses marked as having been provided by people from this thread who had sent their lenses in.
Exciting times we live in !
Matt Uhry
www.mattuhry.com
I tried that with a camcorder once...never worked quite the same again
That hacksaw blade looks a little used. I hope you replace it before you modify my lens. I like a clean hack.
That blade is so worn because I just finished an overhaul on a 24-290 Optimo..
Lots of hacking there. You should see it after we install a PV mount on an Optimo.. Then we replace the blade.
