Raffi Kryszek
Active member
Hello everyone,
Clifton Production Services and CoolCameraGear.com have released a new iPhone/iPod touch application called "Pocket DIT" available on the itunes store. (don't worry....its FREE)
Download from iTunes or directly from our website at www.coolcameragear.com under the Products/FREE Software section.
This is your cinematography “cheat sheet" that includes:
•RED ONE virtual menu navigator that allows you to navigate the RED’s
menu system before even approaching the camera.
•Menu search feature lets you locate a particular menu function within
the RED’s menu system
•Depth of field calculator with near focus, far focus, and hyperfocal
distances for 16mm, 35mm, and RED formats
•Transfer time calculator helps you estimate the amount of time it
will take to shuttle files from a source to a destination given your
specific configuration
•Storage calculator allows you to estimate the amount of storage
required for RED footage
•Time calculator helps you estimate the duration of footage given a
particular file size
•Max fps indicator helps you determine the maximum frame-rate/timebase
that can be recorded given a particular RED configuration
•(coming soon) Bluetooth roll/cut control
This is just sort of a side-thing for us so let us know what you think.
Thanks much
Raffi
Thanks much
Raffi
