- Moderator
- #1
Evin Grant
Moderator
- Dec 28, 2006
- SoCal
- www.evingrantdp.com
I had a chance to preview the new Zeiss Compact Primes this morning at Band Pro thanks to Michael Bravin.
first of all I'm not going to go into optical quality much here. This is for two reasons first off these lenses use the same glass elements and formulas as the widely reviewed and used Zeiss ZF still lenses. Secondly these will have their chance at our upcoming SALT test along with many of the other new optics coming available. What I will say is that these lenses differ from ZFs in two ways that affect their imaging...
1st, the glass elements are hand picked for quality and consistency.
2nd the lenses feature a beautiful 14 blade iris that should substantially improve bokeh and OOF object rendering.
OK so these barrels rock!
Double sided focus scales with more witness marks than you can shake a cinetape at. Smooth consistent focus not too dampened and not too loose, with zero backlash pretty much on par with UP barrels.
Consistent barrel size, OD and internal focus for easy lens swaps...
And because I know you'll ask for it...
A frame grab and BTS shot. (This is from the superb 28mm T2.1, WFO at minimum focus distance)
